05-09-2007, 07:44 AM
Re: Broken camshaft on new 07--what to do?
Originally Posted by Only Toyota for me
Okay,
Just talked to the service manager today and here is the verdict.
It will have intake & exhaust manifolds and the whole nine yards. They may be using the existing heads, but dunno.
Something sounds off with what they have told you. I think you will get a complete engine for the following reasons a) They install complete engines on the assembly line. b) The intake and exhaust manifolds are attached to the heads so the heads must be there. c) The reason you are getting a new engine is two-fold; they want to make sure there is no collateral damage down the road and they want the complete engine back to try determine the cause of failure.
Personally, I would baulk if they attempted to re-use the heads. I would want to see the pistons to make sure there was no signs of valve contact. I'd also insist a bleed down test be performed on the bank of cylinders that had the broken cam.
'07 Tundra Slate Metallic SR5 4x4 TRD 381 HP/401 TQ
Blind allegiance is not my strong suit
