Re: Brake fluid change
I use only DOT 3
In the cap of the resevoir says "use only DOT 3" so I'm going to stay with DOT 3. Some people say that DOT 4 can be used, that is better, that has a higher boilling point, true but why TOYOTA doesn't say that DOT 4 can be used? don't know the answer but I can be sure that using DOT 3 will be following TOYOTA's requirements. THey built the truck, they must know more than me...
