Old 05-13-2007, 01:01 PM
dsmonline's Avatar
dsmonline dsmonline is offline
Last Online: Yesterday 06:30 PM
dsmonline is on a distinguished road.
dsmonline's Photo Albums
Red face Re: ReadyLift Leveling Kit Install (pics)
Originally Posted by zekeman View Post
Thanks for posting... my ready lift goes in Tuesday of this week it looks as though your front end is up in the air a little bit?Also do the spacers only go in one way I noticed that the bolt holes and studs are not drilled exactly at each corner of the spacer, two of them look off center?On the Ready Lift web site thay say they are my spacers say they are 2.4 inche spacers.Wondering why you say it is a two person job I was gonna attempt it by myself..
They only go on one way, the strut is marked as 'out' and the spacer is marked with a line to match. Web site says they are 2.4", order invoice says it is a 2.25" kit and the actual measurement of the spacer is 1.75". I can understand how a 1.75" spacer makes a 2.25" lift given the change in the spring rate and all, not sure how I got 3". Maybe I should double check the before measurement at the dealer on another truck.
As for the two person suggestion, it's your call, I am just glad I had my brother to help. It probably saved an hour of work and a lot of frustration. There are times when you need to be under the truck and also have the spindle moved out of the way at the same time.
