Originally Posted by dsmonline
They only go on one way, the strut is marked as 'out' and the spacer is marked with a line to match. Web site says they are 2.4", order invoice says it is a 2.25" kit and the actual measurement of the spacer is 1.75". I can understand how a 1.75" spacer makes a 2.25" lift given the change in the spring rate and all, not sure how I got 3". Maybe I should double check the before measurement at the dealer on another truck.
As for the two person suggestion, it's your call, I am just glad I had my brother to help. It probably saved an hour of work and a lot of frustration. There are times when you need to be under the truck and also have the spindle moved out of the way at the same time.
Thanks for the extra info..just so you know I ordered mine direct from ready lift and on my invoice it says nothing about the height of lift...I have the same color truck DC only with TRD.Your truck looks great especially with the ready lift installed, I cant wait...
