  #25 (permalink)
Old 05-17-2007, 12:20 AM
lelandstanford's Avatar
lelandstanford lelandstanford is offline
lelandstanford's Photo Albums
Last Online: Yesterday 09:50 PM
lelandstanford is on a distinguished road.
Default Re: Auto vs. stick, your opinion.
Originally Posted by grumpy in NH View Post
Automatics typ are MORE efficient on the highway with a stick due to LESS mechanical losses thru the drivetrain with a lockup converter (yes I said automatic) ........ Recall that manual tranny's have all gears in constant meash and are often lubed with 85W gear lube (sim to a 40W motor oil - the weights dont directly translate across motor to lube oils) and tend to generate heat in OD gear and thus less efficiency.
Incorrect.
Take Yaris as example:
5-speed manual is 21.7MPH/1000RPM (top gear) , 75W-90 (most likely dino) and 34/40 MPG.
4-speed auto is 22.2MPH, WS ATF (synthetic) and 34/39 MPH.
How can auto model rev less on highway (TQ lockup) with synthetic fluid but produce less MPG?
2005 Tacoma AC 2WD 2.7L 5M
