Old 05-23-2007, 11:03 AM
noserider99 noserider99 is offline
noserider99's Photo Albums
Last Online: 07-11-2007 03:24 PM
noserider99 is on a distinguished road.
Default Re: How many miles do you have on your Tacoma WITHOUT any problems?
Originally Posted by pug407 View Post
I have a 2003 doublecab V6 with TRD and SR5 package but I can't manage good MPG, recently I found out trough testing that the Deckplate Mod was killing my MPG, why? I don't know, but now I'm getting more miles, don't have the numbers yet but I estimate a 10% more maybe better...
What is ISR mod??
ISR = Intake Silencer Removal. Search for a writeup on TTORA and/or Yotatech.
As far as the deckplate job on your truck, did you reinstall everything correctly? I know it's an easy mod but....
Did you disconnect/reconnect the battery (flash the ecu)? If not, it takes the ecu time to reprogram itslef to accomodate the increased airflow. Otherwise, not sure.
I check my mileage religiously, and even put the deckplate back in for a stretch to see if it changed anything. Nope. Still about 18-20 mpg with the deckplate covered, and 20-22 with it open on my truck.
2004 X-cab V6 4x4 TRD SR5 (5-speed) - Lunar Mist Metallic
ARE-Z Series Shell, Rhino Liner spray-in bedliner, 4" Deck Plate Mod w/K&N Drop-in fliter, AirRaid MIT, 24" Magnaflow muffler (#12286), Wet Okole "TRD" Seat Covers.
