Old 05-28-2007, 11:08 PM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Default Re: Lost smart key warning!
Originally Posted by Swanny1172 View Post
Are you 100% sure about that? I have read several different places that this is not the case and that you can reprogram keys to different vehicles.
--edited on 5/21 to add:
In fact, I have confirmed this with my local dealer. You can use a key that has been programmed to another vehicle. However, you will have to have a new key blank cut to be able to use the emergency key to enter your vehicle in the event that the battery in your SKS fob is dead.
M factory rep says it can not be done.
I programmed a BRAND NEW KEY to a prius so the customer could have 3 masters, and something happend in the car deal, so he ended up not getting the key and some other stuff.
We needed a Master for another customer who lost ther keys and the previous key I had progrmmed to the other vehicle WOULD NOT program to the 2nd Prius, Thats when I called TAS (Toyota support and my factory rep)they both said the same thing. ONCE PROGRAMMED to vehicle "A", it can no be programmed to vehicle "B". I am talking about the "SMART KEY" only vehicle.
I'll experiment on my parents prius, next oil change, and see if I can program their key to another prius.
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
