  #18 (permalink)
Old 06-05-2007, 01:12 AM
Tennesseestorm's Avatar
Tennesseestorm Tennesseestorm is offline
Last Online: 08-04-2009 08:26 PM
Tennesseestorm is on a distinguished road.
Tennesseestorm's Photo Albums
Default Re: 2001 V8 Tundra timing belt replacement
I have heard of many problems on the 2000-02 models. 03's seem to be better. Mostly, it seems like something in the planetary? or something like that goes out in them and it mostly effects the O/D. Some people reported problems at miles as low as 30K, but sometimes it does not occur until after 100K (if even then). I was told that if you make it to 130K+ miles, then you will likely be OK.
My O/D is fine and all shifting it fine, except that the 2nd to 3rd shift, shifts with a "kick" under anything but light acceleration. Sometimes it will "flare" before it shifts into 3rd. Toyota dealer said all is fine and no cause for concern, but I wonder. The PO had the original fluid changed at 69K and now it has 104K. The Toyota tech said the fluid still looked and smelled like new and he would not recommend changing it right now. I may take it to a tranny shop to get another opinion.
Sounds like your tranny is doing perfectly well.
Originally Posted by Mongoose View Post
My transmission shifts fine and smooth. I have 85 k miles on the truck and I have never serviced the transmission. I never do any pulling to put wear and tear on it, so I wasn't concerned about having it serviced. How widespread is the transmission problem?
As i mentioned before, had I known my timing belt was in near perfect condition I would have waited another 30 to 40 K miles beforer changing it.
