Re: Highlander HB trailer wiring harness install?
It is referring to the AUX battery, the small one located under the hood on the passenger side front.
Please do not attempt to disconnect the HV battery. We have to wear LINEMAN Gloves to handle those things. IT WILL KILL YOU IF TOUCHED WRONG.
25 yrs with TOYOTA
