Re: tacoma DC 4x4 auto vs. manual
1. The manual probobly has a numerically higher rear end gear ratio, as my 5sp 4Runner does. At the same speed, you are turning higher rpm's than an automatic in overdrive.
2. Clutch cancel was designed for 4wd lo applications, typically tricky uphill starts that would burn the hell out of your clutch.
