Thread: Check engine!!!
Old 06-14-2007, 12:18 PM
LeeinAZ LeeinAZ is offline
Last Online: Today 11:33 AM
LeeinAZ will become famous soon enough.
LeeinAZ's Photo Albums
Default Re: Check engine!!!
It will also come on every 4500 miles or so to remind you to change your oil. It can be manually reset per instructions in your Owners Manual.
1. Turn the ignition switch to the “IG-ON” position and make sure that the odometer is set to “TRIP A”.
2. Turn the ignition switch to the “ACC” or “LOCK” position.
3. While pushing the “TRIP” meter reset knob, turn the ignition switch to the “IG-ON” position.
4. With the ignition switch in the “IG-ON” position, keep holding the “TRIP” meter reset
knob (for at least 5 seconds) with the LCD counting down as shown in the illustration.
When the reset is complete, the display will show “000000” for 1 second. Then the maintenance light will turn OFF.
5. Release the “TRIP” meter reset knob when the reset is complete.
'07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
