Originally Posted by dhawman
Seat belt chime
1. Turn the ignition switch on (without starting car)
2. Press the ODO/TRIP switch until the odometer displays "ODO"
3. Turn the ignition switch off
4. Turn the ignition switch on
5. Press ODO/TRIP switch immediately (within 6 seconds after turning the power switch ON) and hold it down for 10 seconds or more.
6. Continue holding the ODO/TRIP switch and fasten the front passenger's seat belt.
7. Check that the odometer displays either "b-on" or "b-off" (it will be "b-on")
8. Press the ODO/TRIP button to change the display to "b-off".
9. Turn the ignition switch off.
10. Turn the ignition switch on while depressing the brake pedal.
11. Check that no buzzer sounds when setting on the front passenger seat.
Can anyone tell me if this works for the Tundra?
