Re: Avalon Cooling Fans won't shut off?
3. The coolant temp sensor could have gone "OPEN".
2.Usually tho it is a bad a/c pressure switch, located behind the drivers headlight near the radiator.
1. The other common thing is a ENGINE MAIN RELAY, it is located under the hood in the fuse box. It controls the fans as well.
Those are the top three things that come to mind.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
