  #37 (permalink)
Old 06-16-2007, 11:09 AM
exyz exyz is offline
Last Online: 07-02-2009 12:40 PM
exyz is on a distinguished road.
exyz's Photo Albums
Default Re: Need wiring help with set of RAV4 OEM fog lights
Hi Im new this TS I just recently I have my fog light Rav4 06 from ebay. I just want to make sure that I connect it right. " Black wire -Ground ,Red wire -Fog light signal and the Yellow wire - illumination signal. Pls let me know if im on the rigth track
thank
Originally Posted by mustang67408 View Post
Hope these help, they are for a 2006 RAV
p.s. If you subscribe, you'd have access to all this and more
If your using the factory wiring it should work. As long as the body ECU sees the proper signal it will send the signal to the combination meter to illuminate the fog light indicator. Your probably going to need the factory headlight/foglight switch. It sends a signal to the body ecu, which in turns send a signal to the combination meter.
