Old 10-19-2002, 06:48 PM
Stooge Stooge is offline
Last Online: 03-12-2006 06:51 PM
Stooge is on a distinguished road.
Stooge's Photo Albums
Search the site - lots on exacly what to do. The lower hose to the air-to-oil transmisstion cooler in front of radiator is the pressure line. Disconnect it, insert a 1 foot section of 3/8" copper tube and bend it down in front of the radiator under the bumper. Put that end in a gallon jug marked at about 1/2 (two quarts). Start the engine, fill jug to line, stop engine. Dump jug, add two quarts SLOWLY down the dipstip for tranny. Repeat until 12 to 15 quarts are changed through. Reconnect everything. Check the fluid level and leaks. Your done. Next day, check fluid level again. So easy you should do it every year!!!
