Originally Posted by OLDMXGOLFER
Hi, I'm sure you're tired of hearing from people about your post, but I've just joined Tundra Solutions and the information that you've provided is great. I read one of your later posts where you indicated that you didn't like the PBR Ceramic pads because of dusting and was wondering if you know the correct OEM Toyota pad part number that I should use if I go with all of the other parts (rotors & calipers specifically) for my brake fix? Also, would it be worthwhile to used stainless steel braided brake hoses? Thanks
The Toyota pad number is 0446535290. They list for $63.00
SS brake hose are not necessary for normal street driving. Factory hose are capable of lasting the life of the vehicle in most cases.
If you do a lot of off roading, they are good insurance.
Thanks,
Mike
