Thread: Surging...help!
Old 06-26-2007, 03:13 AM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Default Re: Surging...help!
Tundras do NOT have EGR's.
A bad coil pack should set the engine light and/or set a code.
I would also loose the Jet Chip.
Have someone read the codes, they can be "pending" and not set the engine light.
Low fuel pressure will make a vehicle surge and not set a code or engine light. (2000 tundras are known for this)
Dirty fuel filter from a tank of bad fuel or dirty fuel.
CHECK FUEL PRESSURE
Clean the MAF sensor might help
Try dropping the exhaust before the cats, they might be plugging up.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
