Thread: Surging...help!
Old 06-26-2007, 05:44 PM
beboff's Avatar
beboff beboff is offline
beboff's Photo Albums
Last Online: 10-12-2008 08:24 PM
beboff is on a distinguished road.
Unhappy Re: Surging...help!
Originally Posted by whateverz View Post
Just had it checked and it is throwing no codes. He said the O2 sensors were not reacting as fast as they should (lazy). and we were noticing that the Downey headers have the O2 mount bung off to the side and not directly in the flow. But this problem was not evident directly after the header upgrade. He thought fuel pressure too, cause flow was registering good when it was started. He recomended tapping the fuel rail to get a pressure read.
Is this how it's done? What is the correct procedure? Little leary of tapping my fuel rail.
The fuel pump makes total sense. Cause it's only when it needs lots of fuel. I replaced my sending unit and didn't spring for the pump like a jacka!@. There was lots of magnetic particles, and I tried to clean it up as well as possible. BTW, it was doing this before messing with the sending unit. And the tank strap bolt got stripped and I had to re-tap new ones due to tank damage. So I am not looking forward to dropping the tank again.
Don't the pumps just go when they are bad? Or can it be a slow degrade? What about a Walbro?
And next time I am up in Huntington Beach I will bring my ECU and have Jet flash it back to stock. I don't have much faith in them.
If you find the problem let me know.
