Thread: code p1135
Old 07-01-2007, 11:27 PM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408's Photo Gallery mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Default Re: code p1135
Originally Posted by sinewbi View Post
my 02 sienna has same code(p1135),but i don't know where is b1s1 o2 senser located, please help
Bank 1 is the bank closest to the firewall . Bank 1 denotes the bank with cylinder #1 in it. Sensor 1 is the first sensor in front of the CAT.
Attached is a document that may help you see which is which.
Hurley Chuck
How do you test the heater circuit of bank 1/sensor1 to be sure wheter its the heater or the sensor. I also have the P1135 cdode at 66000 mile on my v6 tundra
see attachment
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
