Old 10-25-2002, 11:54 AM
akauth akauth is offline
Last Online: 08-16-2009 10:56 AM
akauth will become famous soon enough.
akauth's Photo Albums
Default Re: mine...
Originally posted by cappi
I'm sure Alan's procedure will work also but I just followed the directions in the "Garage" for an entire change. I used Mobil1. The directions in the Garage worked perfect... and very easy too. Actually, was easier(although longer) to change the ATF than to change differentials and transfer cases.
That advantage that I found for the using the top line as someone else suggested on here first is that it's a lot easier to connect a piece of trans line to it and drain the fluid to whereever you wanted. There is also the advantage of flushing the cooler, which you can't do otherwise. But that's a pretty minor advantage. Too, if you DON'T have a cooler standard, you can just plug the drain line into the outlet of the cooler built into the radiator instead and put the other end in your container.
Kind of six of one, half dozen of another, but I think it's much more convenient to use the upper fitting as you'll only need an extra length of trans line to drain it while not making any mess.
Alan
