Originally Posted by ballin
whew, glad to see that somebody has the same problem(i guess). i turned off the trac.and vsc and it was in drive.would not shift out of 4th. turned everything back on and it shifted fine. tried it again with everything off and it did fine. i thought maybe the trans wasnt fully warmed up or something,dunno. was kinda getting nervous about it.  With all the trac. stuff off it still feels like its not getting all the power that you would expect out of that hoss engine.
I wonder if they need to swap transmission oils? Maybe too thick or thin? Maybe we should all add Lucas transmission additive, lol. For those that find their transmission is sticking in gear maybe worth pooring that in and seeing if it makes a difference ofcourse you'll have to drain some of the other out I'm guessing. Wonder if it will void the warranty? It shouldn't. Toyota should be looking at all options.
