Re: a/c fan not working
Originally Posted by jogan
not sure if this goes in electrical or not but like the title says, the little fan that blows in the wonderful air conditioning finally pooped out. it figures that in the first week of july in the hot state of florida, the a/c fan quits on me. everything else seems fine. all the lights work. all the other switches seem fine. even the a/c is on and the vents on the dash get condensation on em and feel cold to the touch. i just can't get the little fan to turn on. hopefully this is a simple fuse or relay that i can replace. any help would be much appreciated. i'll call the dealer in the morning but it's the weekend so i don't know how much luck i'll have there. thanks in advance.
I assume you tried the blower at all speeds and none worked. If so, the problem is not the blower resistor. If it works on high only, it is a bad blower resistor. Check the 10 amp "gauge" fuse and the 50 amp HTR fusable link. Check pin 5 of the HTR relay for 12 volts(with the relay removed). If there is 12 volts there, the fusable link is good. If the 10 amp gauge fuse is good, remove the HTR relay and jumper from pin 5 to pin 3 of the socket with the blower switch on. If the fan runs, the relay is bad.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Nav system, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Line, 5.7 Killer
