Old 07-07-2007, 09:10 AM
jogan jogan is offline
jogan's Photo Albums
Last Online: 07-12-2007 08:52 PM
jogan is on a distinguished road.
Default Re: a/c fan not working
ok, the 10 amp guage fuse is fine. i assume the 50 HTR relay is fine. now when you talk about checking pin 5 and then running a jumper from pin 5 to pin 3 is where you lost me. when i remove the 50 amp HTR fuse/relay, there's only two posts available. am i removing the wrong thing? and no, the fan doesn't work on any of the settings. i don't think it's a bad fan switch because when the a/c is on and the fan is in the off position, the engine idles fine but when i turn the fan on (even though it doesn't blow) the engine idles changes to indicate a load on it for the a/c.
