Re: a/c fan not working
Originally Posted by jogan
ok, the 10 amp guage fuse is fine. i assume the 50 HTR relay is fine. now when you talk about checking pin 5 and then running a jumper from pin 5 to pin 3 is where you lost me. when i remove the 50 amp HTR fuse/relay, there's only two posts available. am i removing the wrong thing? and no, the fan doesn't work on any of the settings. i don't think it's a bad fan switch because when the a/c is on and the fan is in the off position, the engine idles fine but when i turn the fan on (even though it doesn't blow) the engine idles changes to indicate a load on it for the a/c.
The HTR relay will have 4 or 5 posts that plug in to a socket. It is a seperate item than the fuse. Remove the relay and see if there is 12 volts at pin 5 of the socket, The 50 amp fuse is good if there is 12 volts at that pin. If there is 12 volts, leave the relay out and jumper pin 5 to pin 3 of the socket (with the blower switch turned on). If the relay was the problem, that will make the fan run. If the fan does not run, something else is the cause. I hope that helps. Good luck.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Nav system, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Line, 5.7 Killer
