Re: Clear Corners for 06 DC Tundra...
the oven thing didn't work on the corners because i used too much heat and the corner lenses are too thin so it warped the edge. the headlights are thick enough that you can heat up the silicone and pull them apart. i got the vht from oreily auto parts. you have to order it but it only takes a day or two. and about spraying the headlights, i wouldn't do it. it would block out way too much light.
