Re: Upgrade your early Tundra Brakes In 1 hour
First, Thank you all for the valuable information in this post. Secondly, I'm a bit confused. I was led to believe that the root cause of this braking problem is due to insufficient rear braking, overpowering the front brakes causing the rotors to overheat and warp? It doesn't seem from this post that the rotors are in question and the new calipers don't seem much larger, so how does this fix the root of the problem? Prior to reading the "full" post, I was just going to add Brembo rotors and some ceramic pads, but now I'm not so sure. Thank you for any clarification.
Travis
