07-16-2007, 01:54 PM
Re: Brake Replacement and Brake Fluid
Originally Posted by MEvang
Your assumption is right. As the pads wear the caliper pistons will move out to take up the gap. Fluid from the master cylinder reservoir with take up the room in calipers, in turn dropping the amount in the reservoir.
If you simply push in your caliper pistons to make room for the new pads and no extra fluid has been added, the amount of fluid in the reservoir should return to normal.
Now what you shouldn't do. If you have ABS it is not recommended that the fluid be push bake through the system. Fluid can also carry dirt and moving this dirt can clog up the ABS valves. This is highly unlikely to happen but is it worth taking the chance, probably not.
Since the best time to flush out old fluid is at the time of a brake job, it is best to simply open the bleeder screws and push the fluid out as the pistons are retracted. Then flush the brakes system out with fresh new fluid.
So this is your choice.
Mike
Is there a particular brand of brake fluid that is recommended for the Tundra?
All a man really needs for happiness in this world is a good woman, a faithful dog, and a big-a$$ed set of tires on his truck.
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Audiovox ACA200W Rear-view camera, Audiovox XM Express Sattelite Radio Receiver, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Large Dog
