Originally Posted by Stripped Honda
that is normal if you would have pressed the gas it would have up shifted again .. its just the transmission downshifting to slow the truck down
I actually ran the truck up to a fairly high speed and the transmission did not upshift until I placed the shift lever in "S" position then manually upshifted. This is the first time the transmission has downshifted like this. I was on a downgrade at about 60 MPH when I barely touched the brake to hold my speed steady. I had read other posts about the transmission downshifting when brake is applied fairly hard. This has never happened since I bought the truck. Thanks to all for the replies. I will continue to drive the truck for a while and see how it does. It will be due for 5000 mile service soon. I will have the service person check it out.
