Originally Posted by hkiser
I would check the DRL fuse and if good pull the DRL relay and read for resistance accross its coil. You can also jumper pin 2 to 1 on the DRL relay socket, with the DRL lite up and see if they go to full brillance (with the relay out). Good luck.
Ok, I checked the DRL fuse and it is good. Next I pulled the DRL relay and wasn't sure how to read for resistance across its coil (sorry I'm new to the electrical side of things) but I did connect pin 2 to 1 and the DRL then went to full brillance. Does this mean the relay is bad?
