Re: Ants!! AHHHHH!!!
You can try this.
Ant Problem? Terro = Ant Control Solutions
We use these products in our house, and it does work.
You can use the version that is simply drops, You can leave the drops in your vehicle on a piece of cardboard - you don't have to place it directly on your carpeting or seats. This way when you use your car, you can remove the cardboard - clean and simple. All you would have to do is clean up the dead ants later.
2001 SR5 Access Cab 4.7V8 4x4
OEM: FJ Rims; bed-liner; alarm; running boards; all-weather mats; door sill protectors; 13WL brake caliper upgrade
TRD: color-keyed mirror covers, embroidered signature mats
OTHER: Bridgestone A/T Revos; NGK Iridium IX spark plugs; Skid Row front skid plate; Fumoto drain valve; Vibrant resonator; Magnaflow exhaust tip; Form-Fit deflector; Brembo rotors; Trfytoy window latches; Undercover tonneau; Wheelskins leather steering wheel cover
PENDING: TRD coils, Bilstein shocks; TRD Kazuma LSD; Hellwig sway bar
