Re: Fog Lights Rav 4 - 2007
There are no installation instruction to add fog lights.
If you add (fog lights)(any type) then add the factory relay and install the TOYOTA SWITCH. The fog lights become plug and play and there is no wiring.
You have an aftermarket switch, there's no way for us to know what wire goes to what.
All we can do is tell you how and where to install the factory relay/factory switch and fogs.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
