  #20 (permalink)
Old 07-17-2007, 09:38 PM
tackleberry625 tackleberry625 is offline
tackleberry625's Photo Albums
Last Online: 08-27-2008 06:12 AM
tackleberry625 is on a distinguished road.
Default Re: How many miles do you have on your Tacoma WITHOUT any problems?
Originally Posted by Arb1977 View Post
2002 Taco 5VZFE (3.4L) auto with 72K. The only thing that need to be changed was a leaky ps pump..no biggie under warrenty and the lower ball joint recall. Other than that shes been bulliet proof. I did a tow from california to texas (1500 miles) in the start of last summer about 3500-4000 lbs will no ill effects. Before the tow my buddy and i replaced the fan clutch with a one that comes with the tow package.
I run synthetic fluids from the engine to the rearend and also run a secondary tranny cooler. Take good care of your ride and you and her will live happily ever after.
I have an 02 Tundra 3.4 with 71K. I also have a tranny cooler on it and have run syn oil since new (well 2880 miles after break in). U have to have an extra tranny cooler exp with the trans probs the tundras have had in the early years. No "major" probs, everything has been covered under warranty except the O2 sensor (ball joint recall, cat converter, p/s exhaust manafold crackd for an unk reason and was replaced)
Toyo Guarded 2002 Tundra Access Cab SR5 3.4L V6. Valvoline Synpower protected engine and MMO protected everywhere else.
