Originally Posted by KFlash
If you do a search under handling and suspension, I continued the conversation. As it turns out, other have had the same issue and found it to be a torn dust seal around the steering shaft. All that noise coming through a small hole.
Yes, but likely it's the more common cracked manifold, since it only does it for a short time after starting up. Is the torn boot from "off roading" or can any vehicle have that? The only ones I've seen are on older rigs where age and heat cause the rubber to deteriorate.
