  #57 (permalink)
Old 08-05-2007, 11:37 PM
sparky50 sparky50 is offline
Last Online: 09-07-2007 10:59 PM
sparky50 is on a distinguished road.
sparky50's Photo Albums
Default Re: Heater quit... sort of
Originally Posted by chasdaddy View Post
I actually have no heat. Just bought, tried heat couple days ago. Turned knob, never got heat. I've read all the different threads. Tried what each suggested, took unit out of dash, wires didn't appear to be broke. The board did look a little discolored. Could the board itself be the problem? What is the cost of the Temp control board? Are could it be something else?
Thanks,
Charlie
Hi,
Certainly the board could be defective.. I don't know if Toyota sells it by itself. Are you sure the wires are making good contact? I haven't seen anyone actually find that a board was blown yet... just broken solder/wire joints. Otherwise, hit the wreckers I guess. An alternative might be a good electronics repair place (these must still exist somewhere), as this appears to simply be a potentiometer... a variable resistor ... they could evaluate whether it was bad, and likely come up with a replacement.
Good luck,
Garth
