Old 08-07-2007, 10:59 PM
Shite2k Shite2k is offline
Last Online: 11-16-2009 02:03 AM
Shite2k is on a distinguished road.
Shite2k's Photo Albums
Default Re: Bucket seats for a 93 toyota P/U ?
On a 93 compact pickup, at least an xtra cab which is what I have, I did the bucket seat swap from my 60/40 front bench to the SR5 bucket seats.
The passenger side bolts right on no problem.
The Driver side will require you to make an offset bracket (Not too hard, just need some 1/8" or thicker metal about 3-4" by 1 to 1 1/2" wide and 2 carriage bolts) for the front right leg. The Front left and rear left legs (if you're facing forward sitting in it) line up no problem. The back right leg requires a very minor amount of muscling it over to get it into position and I suggest putting the bolt from underneath an then muscling it over onto the bolt and then putting the nut on top and ratcheting it down.
The SR5 buckets in the 89-95 pickups are one of the most comfortable bucket seats Toyota ever put in a truck.
