Old 08-09-2007, 05:38 PM
42GAMI's Avatar
42GAMI 42GAMI is offline
Last Online: 11-15-2009 09:49 AM
42GAMI is on a distinguished road.
42GAMI's Photo Albums My eBay
Default How To: Manual Trigger Bypass For Alpine Iva-d310
HOW TO: MANUAL TRIGGER BYPASS FOR ALPINE IVA-D310.
BASIC TOOLS & MATERIALS: Side cutter or wire stripper, About 10’ of wire (color(s) of your choice), shrink wrap or (ghetto electric tape), solder iron & materials, 2 x SPST switches 10amp, small pliers, and beer.
DIFFICULTY LEVEL: 1-2 BEERS
BACKROUND ALPINE MONITOR SAFETY SCHEME:
Model IVA-D310 may apply to other models.
Since the advent and prevalence of head unit monitors, more audio/stereo manufacturers are incorporating increasingly sophisticated schemes to prevent users from viewing the monitors while their vehicle is in motion. For obvious reasons, as well as, laws in most states, there is a considerable safety issue with regards to this subject. I will not go into that here.
I will not cover any previous safety schemes, only that of the ALPINE IVA-310. Alpine currently employs a picture prevention scheme that utilizes multiple signals of DC power and chassis ground. Alpine may also incorporates voltage or load sensitivity, signal duration, and signal sequence too. Pacific Accessory Corporation (PAC) makes a bypass trigger module called the PAC TR-7, preprogramed specifically for Alpine units. Problem is that not all TR-7 triggers work properly due to some reason or another; voltage spikes, load resistance, and pulse duration are some of the problems sometimes associated with the use of the trigger module. I have personally gone through several PAC triggers, noise filers, and load resistors which have lead me to devise my own scheme to defeat the picture safety bypass feature.
HOW IT WORKS BASICS: The Alpine picture defeat scheme works on a few simple principals.
1. Foot brake wire = DC current (+12v)
2. Parking brake wire = chassis ground.
3. Signal duration
4. Voltage or load resistance.
ALPINE INSTRUCTIONS FOR VIEWING MONITOR:
Place vehicle in park and…
Step 1. Engage Foot brake, keep foot brake pedal depressed.
Step 2. Engage Parking brake.
Step 3. Disengage Parking brake.
Step 4. Engage Parking brake again.
Step 5. Disengage Foot brake.
Simple Translation:
Step 1. +12vdc (FOOT PEDAL WIRE)
Step 2. Ground (PARKING BRAKE WIRE)
Step 3. No signal (PARKING BRAKE WIRE)
Step 4. Ground (PARKING BRAKE WIRE)
Step 5. No signal (FOOT PEDAL WIRE)
SOLVES ISSUE: “PICTURE OFF FOR YOUR SAFETY” while vehicle is in motion. You may locate your manual bypass trigger anywhere you wish, I just happened to install mine in my fuse box cover.
1. Choose Manual trigger location and install both SPST switches temporarily for fitment.
2. Locate Foot brake and Parking brake wires from Alpine wire harness, splice in correct length of wires needed to reach location of switches.
3. Measure, cut, and splice/connect 2 appropriate lengths of wire, from switch to chassis ground, from switch to +12vdc constant (choose low amp circuit).
4. Solder and shrink wrap all four wires to appropriate switches. Foot brake wire to switch to +12vcd, Parking brake wire to switch to chassis ground. (since I used same color wire for project, I used different color shrink wrap to identify wiring scheme)
Manual Trigger Bypass Procedure: (Switch orientation simplifies procedure.)
Depending on the orientation of your switches, lets say vertical, up = off. (like mine)
Step 1. both up
Step 2. left down, left up, left down, left up
Step 3. right down
That’s it. You should be able to view the monitor until you attempt to restart your vehicle, then you will have to evoke the manual trigger bypass procedure again.
Only con with using this system is that the picture will always be in defeat mode. If you want to watch a DVD or access advance set up feature of the Alpine HU, you must evoke the manual trigger bypass procedure.
A few more pictures can be found in my TS gallery:
http://www.tundrasolutions.com/photo...y.php?cat=1293
AND DONT FORGET TO READ THIS LINK 1ST! http://www.tundrasolutions.com/forum...e-wiring-tips/
Disclaimer: ALPINE IVA-D310, may apply to other ALPINE models. Information provided is at the sole responsibility of user. The names ALPINE and PAC are exclusive trade marks, etc, of their respective manufacturers.
MODS: (TRD Urban package) - tint, stereo, jack-in-the box antennae ball, and my middle finger.
... Find any spelling errors? Take it up with admin.
...... btw If I offend anyone, get over it. I know I will.
......... Panties are optional.
~ been there, done that, got the panties ~
