  #21 (permalink)
Old 11-07-2002, 07:42 AM
mstever mstever is offline
mstever's Photo Albums
Last Online: 11-15-2007 08:35 PM
mstever is on a distinguished road.
Question Still noisy...
Well I tried stuffing 1/2" foam rope caulking in the space where the dash meets the windsheild. It worked great for three days and now that rattle/clicking noise is back.
Is this foam rope the same thing that you guys are calling "backer rod" ? I can't find any product called "backer rod"?
What now? Any other suggestions? Should I stuff more foam rope in there?
To reiterate the problem...There is a rattle/clicking noise coming from where the dash meets the window right in front of the passengers airbag. Almost every bump triggers the noise. I can even push up and down on that spot and produce the same noise. It seems to be coming directly under the dash surface.
Does anybody know what is the cause of this problem and what is required to fix it once and for all?
Is there a TSB/recall for this deffect?
If it requires dismantling the dash how long does this take and has anyone here done it themselves?
Thanks for your help...
Matt
