Thread: winch bumper
Old 08-18-2007, 12:22 AM
jamesjr4750's Avatar
jamesjr4750 jamesjr4750 is offline
Last Online: Today 09:53 AM
jamesjr4750 is on a distinguished road.
jamesjr4750's Photo Albums
Default Re: winch bumper
I read into HD bumpers in accidents and came up with some good information on the ARB bumpers about saving the frame with the use of the crush brackets and is what prompted me to buy mine, although ....
I will be bolting the brackets to A36 1/2" thick steel 8" - 9" long by 3.5" wide for my Body Lift (bolted to the frame to lift the whole bumper) and and then some 3/4" or 1" piece of high impact rubber between them and below on the exposed frame. using 10.9 Metric Fine thread bolts and washers, The inside bumper has alot of free play to allow this 1" - 1 1/2" worth of modifying and fit like its not even there.
It will be the same lifting as the side brackets 1/2" A36 Steel 4-5" tall x 4" wide using M8: Metric 10.9 Fine Thread bolts.
Rubber is known for absorbing kinetic energy AND deflecting it like a solid bouncing ball. Ever played bumper cars? Imagine what it would have done without the rubber on the outside when bashing into each-other? Basicly I will be eliminating the metal to metal contact points with the added cushion.
I'll be sure to post pics once I pick the metal up at onlinemetals.com (Seattle base company)
Then taking it to a machine shop to do the welds/cutting out of the holes being able to lift the ARB bumper just like a stock location.
Heres some links:Daughterofromer learned the value of Armor - Accident - IH8MUD.com Forum
Thank You ARB - IH8MUD.com Forum
Frame Bent? - IH8MUD.com Forum
Testimonials from ARB Customers
03' Access Cab Toyota Tundra V-8 4.7L, 4x4
305/70/16 BFG Muds on 4" B/S Wheelers' Offroad Steel Rims
Donahoe Racing Coilovers (cranked 2.5")
Total Chaos Upper Control Arms and Rack Bushings.
ORS upper mount shock hoop kit / FOX Racing 2.0" Reservoir 11" travel shocks w/ Deaver G57 10 pack rear springs
ARB Sahara Bumper with Fog Light Kit and KC SlimLites in Front
