  #60 (permalink)
Old 08-19-2007, 08:28 PM
backdoc7 backdoc7 is offline
Last Online: 09-15-2007 02:26 PM
backdoc7 is on a distinguished road.
backdoc7's Photo Albums
Default Re: Heater quit... sort of
Originally Posted by backdoc7 View Post
ok, i have a variation of this problem in my girlfriends 04 highlander. when her A/C is on, sometimes it blows hot air like the heater is full blast.. she took it to an A/C place and they said the a/c panel you all are fixing is bad. same thing. 900 bucks total fix fromt the dealer. anyway, saw this post and did the three wire fix.. now the heat doesnt blow all the time like it was but the a/c only comes on intermittently. when i first hooked it all together it worked, then stopped shortley after. i have it all apart again and checked my work and all three wires are on ok. any ideas?? thanks. Bill.
update.. not good news.. now a/c isnt coming on at all. before the three wire fix, it was either a/c working or hot air blowing all the time.. now, it seems the hot air problem was fixed with the three wire fix, but the a/c isn't coming on at all.. i've had it apart 3 times checking out my work and checking if there could be another wire, part loose.. no such luck. any insite would be great. thanks. Bill.
