Originally Posted by Toxarch
So when you rewired the factory camera for your head unit with RCAs, I am guessing you used the black wire for the RCA coax center signal feed, the white for the RCA ground, blue goes to chasis ground, and the red was a switched power? Sound correct?
From the factory harness:
Black = 12v (CA+) <-- accessory power must be brought to here
White = Ground (CGND) <-- ground must be brought to here
Red = Center of coax (V+)
Grey = Shield of coax (V-)
