Originally Posted by LS2GTO
Do drag radials have the same feeling that drag slicks have? Meaning do they have a soft sidewall that makes the end of the 1/4 mile feel like you are a bit out of control. If you haven't driven a car with drag slicks (my bro's 442) its kinda scary, great get up and go (no slippage) but at the end when are going near 100 mph the soft sidewalls make for an interesting ride, that being said I would imagine that this crazy sensation would be amplified in a truck that is as high as ours is in the back.
I know that sensation well from 13" M/T slicks on an old V8 H-body. Feels like someone suddenly hits the car on the rear quarter panel. The whole rear end jumps sideways.
No, the Drag Radials have full sidewalls and drive just like a normal street tire. They are basically a performance street tire with a full slick compound on the tread. The only thing that gets you is wear. If you drive them daily, they are on cords after only a season or so.
Another thing to watch for with Drag Radials is the break in period (the BFG brand anyway). When you first get them, they will not have any better traction than a normal street radial. You will be very disappointed at first, but after a few weeks of daily commute, they soften up and stick like glue. They are about half way in between a full on slick and a good street tire for dragstrip traction, which is more than enough for most people at the track.
Another thing to watch is thermal cycling. This is not an issue for most people, but don't drive them in the snow or in cold weather, then try to use them for racing. The sudden temperature change will screw up the rubber and make them spin like a cheap street radial on wet pavement.
