Re: Factory JBL/aftermartket amp
Originally Posted by rzbobby
Hey I think I might have tapped off of the factory amp in the wrong place. When you said install the LOC after the factory amp did you mean tap off of the harness that is in the truck (2004 AC) or the harness that plugs into the back of the unit? If I tap off the harness that plugs into the Nav unit I will only R and L, no front and rear  ........................
No, the LOC is hooked to the Output of the amp --- Or the wires that go directly to the speakers from the factory amp. Not before the amp.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. HAT tweeters, Scanspeak mids and DLS coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar Ultra lamps.
