  #25 (permalink)
Old 08-30-2007, 09:00 PM
Joe1L1's Avatar
Joe1L1 Joe1L1 is offline
Last Online: 02-05-2008 02:06 PM
Joe1L1 is on a distinguished road.
Joe1L1's Photo Albums
Default Re: Navigation Unlocked Sucessfully!!!
Originally Posted by Jer View Post
No, what I mean is that you must first burn AN EXACT COPY OF THE NAV DISC w/o making a single change to it. Simply select 'copy disc' using your burning software and mirror image the factory disc.
This way you make sure your media, burner & software will all jive with your factory deck. If you can't burn an exact copy and make it work don't even proceed to trying to modify the original image and make it work because it won't. If you're able to get the exact copy to play (make sure you disconnect your negative battery to force a reload of the disc) then you can proceed to the process of modifying your files to get the new (read: old) kiwi file to work.
That is exactly what I did, burn an exact copy!! Disc to Disc with no success! But, that could have been the software I used. Regardless, I would stick with the Memorex Dual Layer DVD +R. It has worked for me and a few others out there. They sell them at Staples and Walmart. Verbatim is the other brand I heard that worked. The first discs I tried were Fuji's, which I tried disc to disc with and it failed.
2007 Black Tundra CrewMax Limited , TRD exhaust , Graphite Leather, NAV, 20' wheels, Fully Tinted, Craftec Tonneau Cover
