Re: Stock Air Flow Numbers and Mod
Thanks for the feedback ! I would like to hear how it works out for others.
I should also add that you can go bigger than the size I used, but from the numbers I recorded, it shouldn't make any additional improvement. The exception would be supercharged applications, then bigger may help as long as you also have a free flowing air filter. Even though SC's are pumps, you can't pump what isn't there.
(In case some are wondering, I did consider simply upsizing the intake hose from the fender, but decided against it because it looked to difficult to get in there and cut the inner fender neatly, and then the big question... was some of the restriction caused by the fender cavity as it does get mostly sealed up with the plastic inner guard , and cutting holes in that just lets dirt and water in.)
Good luck with your mods !
