  #36 (permalink)
Old 09-05-2007, 01:18 AM
jlscielo jlscielo is offline
Last Online: 09-05-2007 01:18 AM
jlscielo is on a distinguished road.
jlscielo's Photo Albums
Default Re: Sun Visor Problem
I have the same unsafe sun visor issue on my driver side visor of my 02 highlander and I will try to take apart the visor joint and tighten the screws. It really is a safety issue and when it hits my head sometimes when I duck to look under it in a tricky situation, it is not pleasant since it is heavy and very annoying. Of course I never put anything on top of the visor, ever, and I asked the dealer about replacing it and got the same $600.00 fix it solution since the warranty was not in effect anymore. My dealer even said that I could not replace it with the plain one, so if I cannot fix it by working on the bracket, then I will try to get the visor without the home system on it since I never even used this function anyway and I will try to have someone else install it if they will not. Thanks for the advice. I just finally had my last straw and it is annoying to know my whole family drives Toyota forever and Toyota will not fix this dangerous issue with a reasonable solution once the warranty is expired.
