09-13-2007, 04:58 PM
Just a Herbicidal maniac.
Re: How to correctly detail your auto
Originally Posted by Brandon1
What is the perfect it # on the bottle?
Thanks Brandon. Here's a link to 3M's web page for the product. I'm not sure about the #. From the web page it says " Safely and effectively removes grade 1200 or finer sand scratches, other fine scratches, medium oxidation, coarse swirl marks or water spots, and leaves a fine finish. Excellent for hand compounding applications." They also say " When followed by the 3M™ Perfect-It™ Foam Polishing Pad Glaze, this two-step system delivers a show-car luster in record time. Use with 3M™ Perfect-It™ Foam Compounding Pad (PN05723)."
Thanks for the Mother's Power Polish suggestion as well. Do you think I should use a 'compound' instead of a clay bar at this point with my paint? I appreciate your help.
