Old 09-15-2007, 01:41 PM
Jwitz's Avatar
Jwitz Jwitz is offline
Jwitz's Photo Albums
Last Online: 10-23-2008 08:55 PM
Jwitz is on a distinguished road.
Send a message via AIM to Jwitz Send a message via Yahoo to Jwitz
Default Re: 4wd Not Engaging
I wish I knew for my own purposes, but I have some off the top of my head sugesstions. You could turn on acc (not engine running) and have someone hit the 4wd button and find out if any noise is coming from your add unit. If not I would probably pull the connector and attach a light to the connector (this would be good if you had the toyota wiring diagram). If the connector has no positive signal, then maybe a fuse or relay has gone. if it's okay, then its certainly possible that the add unit has gone. I would say if the dealership wants more than 1500 to replace it, you would do better to buy the manual hub kit and rig the add to lock (which I have no idea how to do...) sorry to be so vauge, but I really have no idea, simply suggusting what I would do in your situation...
2000 Tundra
4x4
6spd
v6
285 Nitto Terra Grapplers
Donahoe Racing Coilovers
Total Chaos UCA's
arb bumper
12000lb warn w/ amsteel line
optima batt, 130amp alternator, KC daylighters
Poly steering bushings
custom long travel swaybar links
HAM: KI4RXK google me! www.gaprs.net
