Originally Posted by cruby
Hi. 1st time on this site. Looking for help on 2002 Sienna right power sliding door. Sounds like I have the same problem as described here. Fails to shut, but will open using power door switch. I've tried the reset, but got no change. I'm getting ready to pull the interior cover to get access to the motor & ECU. Must I change out the ECU, or could it be just a switch or contact problem since the motor still turns to open, but doesn't reverse to close? Any pics of the ECU out there so I make sure I pull the right part? Any idea of the price range for this ECU.
It needs a Right SLIDE DOOR ECU, it is a very common problem.
Its fairly easy to change yourself.
PM me if interested
I know of no picx, unless someone here ar TS has taken some of their replacement.
