Old 09-22-2007, 10:17 PM
PS-RagE's Avatar
PS-RagE PS-RagE is offline
Last Online: 10-12-2009 02:05 PM
PS-RagE will become famous soon enough.
PS-RagE's Photo Albums
Default Common Signal Lines for the 2007 Tundra
Since this question seems to come up quite a bit, I thought I'd make a single thread to identify common signal lines required for aftermarket NAV or camera installation for the three different factory-supplied stereo types.
Speed Sensor:
For the navigation unit it is pin 3 of connecter K6 (white wire).
K6 looks like this:
For the head unit with a separate amplifier, it is pin 4 of connecter K9 (white wire).
K9 looks like this:
For the head units with a built-in amplifier, it is pin 3 of connecter K3 (white wire).
K3 looks like this:
Reverse Indicator
For the navigation unit, it is pin 5 of connecter K6 (green wire)
Again, K6 looks like this:
For all other models, you have to use the connecter for the backup monitor in the headliner. I can’t find reference in the schematics (AP1?) but it is the green wire on this connecter:
Factory Backup Camera
For the navigation system, it is pins 21 to 24 on connecter K7
K7 looks like this:
Pin 21 is the camera’s ground.
Pin 24 is supply voltage for camera
Pin 22 is the positive lead for the video signal
Pin 23 is the negative lead for the video signal
For all other models, again you need to use the connecter for the backup monitor.
White brings ground to the camera
Black brings supply voltage to the camera
Red is video positive
Grey is video negative
I hadn’t thought of it at the time when I did my installation, but power and ground must be on this connecter. The wires left over are blue and violet. Anyone want to take their roof console down to measure out the lines?
Dale McLean
aka PS-RagE
House of RagE
See Road RagE II thread for details
