Thread: ABS Light
Old 09-27-2007, 06:51 PM
LGL002's Avatar
LGL002 LGL002 is offline
Last Online: Today 09:34 AM
LGL002 will become famous soon enough.
LGL002's Photo Albums
Default Re: ABS Light
Not exactly where they are other than at each wheel near the brake front rotors and rear drum assys. They sense whether there is wheel rotation or not to provide feedback to the ABS computer about what's happening traction wise. The reason I mention them is that you said the light flickered when you hit bumps. It might be a wiring connection loose or a mount has come loose. You might also check the main electrical connector right at the ABS distribution unit on your right under hood fender-well. It'll have a multitude of steel brake lines in and out of it and has a handle type release that you need to move up or down to disconnect the wiring harness.
Larry
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
